Ring main help | Page 3 | on ElectriciansForums
Discuss Ring main help in the UK Electrical Forum area at ElectriciansForums.net
Mark.W
Swindon, Wilts
Hi
I was wondering if someone could give me some guidance on a ring main please?
The ring consists of 21 CCTV columns drawing 5A each. The total length of the ring will be 1600m.
Is there a calculation I can use to calculate correct cable size and breaker rating?
Many Thanks
Mark
If they have LED illuminators then driver inrush might be a problem, and although the running current isn't 5A it might be necessary to design as though it was, unless sequential on-delay timers can be fitted.
It would work out a damn site cheaper to hire a consultant!
What would 'work out cheaper'? ... and would it? It is interesting how we all scramble over each other to help one moment, and the next suck our teeth and say get an expert in. Besides which, in my experience consultants borrow your watch to tell you the time and often charge an exorbitant rate to do so!
of course it would work out cheaper the fools are asking for 100amps to feed the pillars not accounting for vd over 1.6km
im guessing around 95mm ring lol
Reply to Ring main help in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
