ring main problem | on ElectriciansForums
Discuss ring main problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
ANT68
I changed a cu yesterday, dual rcd board, everthing going well until rcds start tripping. Done insulation resistance on circuits, readings low. Found one dodgy cable, but started to tie myself in knots, going back today so any advice would be appreciated
The amount of times I have had this problem on a CU Change is unreal.
Borrowed neutral on the lighting circuit. Put that on my Headstone.
Keep calm and carry on test each circuit n/e make sure the n go to the correct n bar process of elimination.
Did you do n/e test before starting
Reply to ring main problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
