Ring Main Tripping MCB | on ElectriciansForums
Discuss Ring Main Tripping MCB in the Australia area at ElectriciansForums.net
I
irishsailor
A friend has just called saying his power circuit keeps tripping the MCB, he said all appaliances are plugged out?
Any suggestions lads
Irish
You need to ask some BASIC questions first, Has any one been playing with the wiring, is it the upstairs or downstairs ring, if downstairs is it wooden floors.
Number of outcomes downstairs with wooden floors could be water under the house seen this a few times, Rodent damage or even a loose wire.To be honest you would need to test it, Start with basic testing continuity then insulation test. Minimum insulation is 0.5 at 500v test.
Hey chaps.
I'm a little confused, an MCB provides overcurrent protection, where as an RCD provides earth fault protection.
The only time an MCB would operate is under overload conditions. (See below)
Do you mean RCD??
Cheers.
PS, sorry short circuit also, just become a Dad for second time no sleep and too much work....bad combo.
Reply to Ring Main Tripping MCB in the Australia area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
