M
malcolmsanford
all these protons and neutrons work better with a bit of heat up them lads .................
We always wire, if not using power trac systems a 4mm ring, without RCD protection.
If your using a radial circuit for high protective current equipment you will need to have your CPC 10mm unless you run a 4mm CPC out in your and a sepearte 6mm back.
By wiring it in a ring you can drastically reduce cable size. You can in fact wire it in 2.5mm as a conventional ring using T+E or singles but we just prefer 4mm.
Rings are still ok. But I always use radials now. Even on kitchens, I just have two radials
Same old story that comes around on a regular basis, and normally started by the incompetent, who neither know how to test or fault find a RFC, or by lecturers that find it too tiresome to teach the unique subtleties of RFCs to the short-course students!!
common sense is the rule .
that's OK, but i would use 4mm for the appliance radial, feeding 20A 2 polo grid switches, 32A MCB.I was thinking of doing this in my next re-wire hopefully sometime in march, how do you divide it up? i was thinking of doing sockets on one and appliances on another, or do you reckon by having appliances all on one radial that would be overload?
