Ring, Radial and Earth | Page 2 | on ElectriciansForums
Discuss Ring, Radial and Earth in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hey guys!
Hope some of you can help me out quickly!
So I've got incoming PV and battery supply of 2000W at roughly 8.7A. This is through an RCBO and to a RCCB 30mA garage style consumer unit, just with a 16a and 6a MCB. The 16A serves 5 sets of double sockets with about 15M of 2.5mm.
1st Question: I've got a door in the way of the ring so I'd have to backtrack, will I be fine just doing a radial circuit instead? It's not much distance so feeding from both ends doesn't seem like a huge concern to me safety wise.
I'm using an earthing rod outside for this.
2nd Question: As I've not got much that can spike can I get away with running standard 10mm 1-core PVC conduit outside rather than 16mm, so long as I bury it deep?
Thanks guys!
Reply to Ring, Radial and Earth in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
