ring test | on ElectriciansForums
Discuss ring test in the Australia area at ElectriciansForums.net
snowplough
Hi Guys,
One of loads of questions,
In A Brian scaddan book ive got it says, if you do the figure of eight, i.e link N-P at the c.u for instance ,then go in each socket on the ring and test between N-P, if you get a nil reading its either a open circuit or a reverse ploarity between N-E or P-E.
When i draw this out and purposely reverse the polarity on both the above i seenm to get a loop through trhe tester indicating i would get a reading and not an open circuit for either N-E or P-E.
Im confused ,your help would be appreciated
Many Thanks
Locket
if you link line and neut and test at a socket but one of the conductors is missing or reversed with the cpc then you wont be able to get a reading for correct polarity you would carry out same test only this time with line cpc
Reply to ring test in the Australia area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
