i have been practicing testing before i return to college in september, i have moved from my test rig onto my own house. i was testing the downstairs ring. the problem i have is when testing at the socket outlets line & neutral cross connected. i should have had around 0.30 at each outlet, out of 12 sockets only half were this figure some were around 0.45 and some as high as 0.76. i double checked all connections were tight, all sockets are metal. Any ideas as i was expecting roughly the same at each outlet. Also there are no spurs. cheers for any help a little confused!
