Ring to radial | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss Ring to radial in the UK Electrical Forum area at ElectriciansForums.net
AdieB
Dorset
Had a call out to a home where the RCD keeps tripping when lounge ,dinning and bed room sockets mcb is switched on. Fault traced to one of the legs from the consumer unit to 1st socket 0.2Meg ohm at best. cable size is 2.5mm T&E there are 10 double and 4 single sockets on the circuit. Reg 433.1 seems to indicate that providing the floor area is limited to 50 m2 (the area in question is 3/4 the floor area of a medium size house. it would be ok to drop out the damaged leg from the consumer unit and socket fuse down to 20Amp mcb and leave as is. Possible to rewire initial leg and reinstate ring but do I need too?
what do you think?
AdieB
PS dropped leg out of consumer unit marked cable with tape and description of fault. Disconnected from socket and put wago type terminals on he cores. Changed mcb to16A (close's that was on van.)
Uk It wasn't long ago that you were complaining that members were having a pop at you all the time!!
It cuts both ways. A debate is one thing, baiting another member is another thing.
Point taken. Apologies. My point that in all reality this is not worth a design still stands. I just think he does this for the sake of argument.
Pure laziness. Besides what happens if the RCD fails?
Replace the faulty leg get it back to how it was before and get paid.
Hang on, that's the customers decision, not yours, I'd have no problem doing either. Give the client the options if they want limited capacity or reinstate the RFC. Also Dilb, I would test RCD in the course of my work. If you think down that track, what if the MCB fails? what if a mouse eats the cable insulation? what if there is a power surge? What if, What if, What if?
I really think any spark worth their salt would give the client two options:
1) reinstate ring (surface or chased)
2) change to a radial circuit
cable calcs are done. In the head of a guy who has enough experience to make these calls.
what do you think?
AdieB
0.2MΩ isn't anywhere near enough to trip an RCD, it needs to be closer to 0.008MΩ so perhaps some more investigation is required. Could you confirm what the poor IR test results refer to? L-N or N-E? I have to assume N-E, but it would be good to just know for sure as 0.2MΩ does sound like something plugged in or a neon?
It's not impossible for there to be a fault with the actual cable run but it's much more likely that the fault lies with an appliance or at a socket/FCU. Have you made absolutely certain that there are no other connections between the CU and this '1st' socket. Perhaps hidden in a cupboard?
As for changing to a radial, I think that is an option once some more investigation has taken place to find the fault. Also, like the others have said the floor space would have to be <50²m and the Electricians Guide to the Building Regs suggests <40m total run length as well. Also I would want to work out what the max demand is 'likely' to be for this circuit before changing to a 20A radial, this could affect your decision.
But.. it also depends on how 'Possible to rewire initial leg' it is if you do find the fault to be hidden in the fabric of the building? If it's easy then decision made, if not then you may sway towards a radial.
There will be other earth leakage in parallel with this 0.02M/Ohm circuit N-E issue. Also a L-N fault would not trip RCD, it must be L-E or N-E for earth leakage. I would hope he has disconnected all loads.
I realise this TJ, but it would just be nice to see it written clearly, much easier to form an opinion then. Also it was 200,000Ω not 20,000Ω, 200,000 is a long way from 8,000 so thats a lot of parallel earth leakage!
Even if Zs was a bit over for MCB, which it almost certainly won't be, I would have no problem in utilising the 30ma RCD to provide satisfactory earth fault disconnection in this instance. This is not designing new circuits, this is getting someone up and running when they have a problem.
As a temporary measure then yes. NOT as a permanent fix!
As for relying on the RCD, is this the depth the trade has sunk where supplementary protection has changed its role?
Reply to Ring to radial in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
Why aren't you asking them?
Recommended Sponsor News
Hi everyone,
