Discuss Ring tripping rcd when connected in the UK Electrical Forum area at ElectriciansForums.net
What he saidHum .... .......... Odd
If it's not the neutral, take a socket off and split into 2 radials and retest.
Is this a new circuit or existing?
I suppose the OP may re-appear?
The Opening post isn't clear.
How are you carrying out IR tests ?
It is possible for a circuit to pass an insulation resistance test when testing between its own conductors, if its isolated from everything else. ( E and N removed from DB)
Something like a screw just piecing through the insulation and touching the live conductor whilst also touching a copper pipe would show the same results.
You need to be more specific.
Reply to Ring tripping rcd when connected in the UK Electrical Forum area at ElectriciansForums.net
