risco config software | on ElectriciansForums
Discuss risco config software in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Midlands
[ElectriciansForums.net] risco config software
hi i have a problem connecting to the risco cs software to agility panel im getting the connection error 20005 any idea why cant connect
iv setup the option in the comms menu on the panel enable left remote code as it is left the engineer code default
its direct to latop to the panel using is rs232 lead
any help would be nice thanks
You need to check port number in Communication settings, think it’s port 4 default just change it to the port number you are using
[automerge]1576952472[/automerge]
Have you got the manual for the CS, if not you can download it from the Risco website
Reply to risco config software in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
