Rj45 cable plugs and sockets | on ElectriciansForums
Discuss Rj45 cable plugs and sockets in the UK Electrical Forum area at ElectriciansForums.net
N
nethystevo
I have just finished wiring a house in cat5e cable and have connected up all the plugs and sockets, but after testing it with the continuity tester it comes up with non-parallel, this happens when the green and orange cores are connected in the socket, but when I take them out it says connected? Really confused with this.
The connections are exactly what's marked onto the socket, this is why I'm struggling to understand why it is not working. I'll triple check my connections but I'm more than positive that they are the right way around.
Sounds like one end is connected to 568A and the other to 568B, which are basically similar but have the green and orange pairs in opposite places. Most connectors show pinouts for both so you might have followed the wrong legend compared to the way you have done the plugs.
E: And Dillb is thinking along the same lines
remember there is 2 standards to connect to 586a and 586b
both of these will probably be marked on the outlet
it is very easy to get mixed up if they are both marked up on the outlet
[ElectriciansForums.net] Rj45 cable plugs and sockets
this is the tester I'm using.
Reply to Rj45 cable plugs and sockets in the UK Electrical Forum area at ElectriciansForums.net
Yes, you run each socket as a point to point connection, and use a switch (it doesn't need to be PoE unless you are wanting to power devices via...
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
