M
mikeyb1000
Hello everyone,
I have just bought a Robin KTS 1620 from ebay. I am new to actually testing and this is my first tester. Continuity seems to work fine though the problem is with the Insulation Resistance function. When I place the croc clips together I get a reading of 1.2MΩ fluctuating to 1.38MΩ (or there about, when it should be reading "OL" or over range) and when I place them onto the lighting circuit I am testing (with all switches closed/on) I get the reading "OL" (which is what I also get when I remove the croc clips from each other as previously mentioned when not testing anything and crop clips connected direct to each other). Now the manual says OL means over range more than 200MΩ , so I'm not sure that the test I'm doing really is over range if its also saying that when the leads aren't even connected to anything!
Can anyone else shed some light on why this may be?
