robin tester. | Page 2 | on ElectriciansForums
Discuss robin tester. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Try taking the neutral feeding the Rcd out
Loop the circuit neutrals to the main switch neutral,and re energise the Rcd
The Rcd should not function without its neutral
Reply to robin tester. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Google says that North Walney is in the Lake District? Have we moved the wall :)
KT66EVA (KT66DL & KEWEVA) - £1073.60 + VAT if you shop about as a combo
