Hi just a quick question.......I have a switch which is being used for a roller shutter door, it simply has 1 wire for common and 1 each for up and down. I belled out between common and both directions to check it was working fine which it was, so it is working how it should.........it might come across as a silly queston, but if it is working fine when I bell out dead it should work fine when it has power going through it? The reason I ask is another electrician had been and looked at the job and has said the switch is faulty, I didn't get a chance to power it up (which they had done) as it was too late in the evening to do so. I'm sorry if I haven't explained it well but just wanted to know if putting power thru the switch could have an effect on it? Cheers
