J
Jim B
Hi there,
I was wondering if someone could help please?
I have just joined the forum and would like some advice!!
I am installing a roller shutter door to my workshop. I have in place already a fused switched spur, this will require connecting to the keyed rocker switch (3 core flex). From this it requires 4 core flex to the single phase tube motor, which has in built proximity switches. The problem I am having is the mains in, where does this go in to the switch? There are 4 terminals marked 1,2,3 and 4. 1 and 3 are for the open/close, 4 and 2, I assume are the mains in.
Could any shed some light please on the wiring of the motor and switch? the flex from the motor is standard 4 core, brown, black, blue and earth!
If it helps the keyed switch is a" link controls" unit.
Many thanks
Jim
Many thanks
Jim
