Roller Shutter stuck in the half way position | on ElectriciansForums
Discuss Roller Shutter stuck in the half way position in the Talk Electrician area at ElectriciansForums.net
TonyD
Greece
Hello All, just posted the same in the introductions forum but thought you more experienced guys may give me some assistance. Appreciating this may not be electrical specific, last evening my roller shutter (patio door type) stuck in the halfway position. The switches are buzzing when operated so suspect problem with motor or capacitor. The shutter does not have manual override and while it can be pushed up manually it will not come down. I need to close it to access the motor. Any help is appreciated
Reply to Roller Shutter stuck in the half way position in the Talk Electrician area at ElectriciansForums.net
