Discuss rotary isolator in the UK Electrical Forum area at ElectriciansForums.net
Yes engineer, he designed the the job, all done on a drawing with all the calcs done for us, that said even if he didn't I would price and install 6mm2 for an air con, hardly any difference in price than a 4mm2, a lot of units are up on roofs and a 4mm2 would be on the limit manc.Is your client the Electrical Designer?
I always thought you were the Electrician!
Talking about the rotary isolators, I find even the 32 amp are tight for space, bloody horrible things.
Yes... What's your point?
I appreciate SY is not the best cable to use, but it does the job.its only a small section that is visible, the rest is under the decking and that section will be decked over shortly so not too bothered about UV issues.
Reason for sy, it's got a slight bit more protection from accidental damage, ok not tonnes, but a bit more than flex.
Maybe flex would have been better, but gin that eventually goes dry etc.
Reply to rotary isolator in the UK Electrical Forum area at ElectriciansForums.net
