Rough cost of big job help needed ?? | Page 2 | on ElectriciansForums
Discuss Rough cost of big job help needed ?? in the UK Electrical Forum area at ElectriciansForums.net
Dl1977
had a quote on this job not sure if it's decent price any help needed ???
Lounge
4 x double socket
1 x single socket above fire for TV
1 x television aerial point and wiring to booster position
2 x HDMI cables from TV to corner
2 x 5amp sockets switched from door
1 x picture light and switch
2 x wall light and switch
1 x centre light and switch (dimmer)
Dining
3 x double socket
Hall
1 x single socket
1 x 240v smoke detector with 10year lithium cell and interconnection
1 x under stairs light position and switch
Rear Entrance/Porch
4 x LED spotlight and switch
1 x double socket
WC
2 x LED spotlight and switch
1 x extract fan with timer, fuse protection and isolation switch
Utility
2 x double socket above worktop
2 x sockets within units for appliances
1 x extract fan and switched spur for control
Kitchen
3 x double socket above worktop
1 x socket above units for cooker hood
1 x 30amp supply for induction hob, complete with local isolation switch
1 x 30amp supply for double oven, complete with local isolation switch
8 x LED spotlight and switch
1 x switched supply to under unit lighting, including connect fittings supplied by others
1 x switched supply to plinth lighting, including connect fittings supplied by others
Rear Living Room
3 x double socket
8 x LED spotlight controlled via 2 switches
Terrace
1 x external socket
Landing
1 x double socket
Master Bedroom
4 x double socket
1 x single socket for TV
2 x wall light positions above bed and switches
Dressing Room
1 x double socket
3 x LED lights within wardrobes, controlled by door switches
En-Suite
3 x LED spotlight and switch
1 x mirror supply, including installation of mirror supplied by others
1 x switched spur to supply under floor heating, including supply of matt and programmer along with connection
Front Bedroom
4 x double socket
Rear Bedroom
3 x double socket
Bathroom
External
1 x switched supply to 2 x LED up/down LED light fittings, 1 either side of front door
1 x switched supply to 2 x LED up/down LED light fittings, 1 either side of terrace door
1 x motion controlled LED floodlight to rear entrance
1 x motion controlled LED floodlight to drive
Further Works
1 x main RCD/MCB distribution board to be positioned within utility room
1 x main earth bonding to water and gas/oil incoming positions
‘Granny Flat’
1 x armoured supply from house DB to new distribution board
Lounge
3 x double socket
Office
3 x double socket
1 x telephone and data point
Stairs
1 x centre light and 2way switching
Landing
1 x double socket
Bathroom
Bedroom
4 x double socket
6 x LED spotlight and switch
External
1 x armoured cable to weatherproof socket for water feature
1 x armoured cable, switched from main house, to supply future garden lighting
1 x LED floodlight with motion control and over-ride
Intruder Alarm
1 x main control panel with battery back up
2 x keypad
2 x external bell box with sirens and strobe light
9 x motion sensor
1 x door sensor to front door
Reply to Rough cost of big job help needed ?? in the UK Electrical Forum area at ElectriciansForums.net
