View the thread, titled "Rubbish products/materials" which is posted in Australia on Electricians Forums.
B
Big n Daft
Right ho chaps and chapesses,
Its time rat out the rubbish. What have you used recently that has been complete and utter poo.
Lets start with anything that has Proteus on the label, and there is some completely useless swa cable out there as well. You know the stuff, its like a coiled spring sitting on the drum waiting to snare you at first pull.
How many of you test tw/e before you use it bought a roll the other day with not good readings
I do :smug: ....................... or rather I used to.
I always thought it was better to spend a few minutes making sure that the cable was OK at the start of the job than spend hours ripping it out & replacing it at the end.
Useless cable grips in FCUs that refuse to hold small csa flexes.
Had to fix loads of those with a cable tie around the flex to stop them pulling out.
Usually found in posh hotels...
Reply to the thread, titled "Rubbish products/materials" which is posted in Australia on Electricians Forums.
