Run Electric Supply to new build garage from 16 amp new build house CU | Page 3 | on ElectriciansForums
Discuss Run Electric Supply to new build garage from 16 amp new build house CU in the UK Electrical Forum area at ElectriciansForums.net
Warwickshire
I am planning to run a power to the garage from a 16 amps RDC from house CU in a new build. I want a power a twin socket, an internal light, and a floodlight. There is a power feed to a junction box on the outside of the house from a CU. My plan is to install a power supply as per the attached sketch. I will call an electrician to connect and test the system. Planning not to have CU in the garage as i will not need any more supply and want to keep the cost down. Any advice will be useful and how much an electrician would charge to connect and test?
[ElectriciansForums.net] Run Electric Supply to new build garage from 16 amp new build house CU
Sorry but I would still instal SWA (inc earth nut) to D.B.
Definitely fitting the SWA that will be connected/tested by an electrician.
Love the brick dust left in the box.
Yeah, it is not only this dust left but lots of other bodge jobs I have found that you can not see on the new build when buying. Site manager does not want to know.
I spoke to the site manager and now they have asked my son to deal with HQ, even though they are building new houses very nearby. Further, most of the electricians in my town are busy until the new year and want to do the whole job. So leaving the project until early next year, unless some electrician is willing to help to connect and test after I have done the groundwork.
Many thanks to all for sound advice and have a fabulous Christmas.
i suggest you do the groundworks, bury a duct at a sensible depth ( 15" - 18" is considered enough, less if under slabs/paving ) with drawstring in. bedded in sand, sand on tot, warning tape then fill in. no sharp bends. then sparks can design the cable size and type and complete the job.
Reply to Run Electric Supply to new build garage from 16 amp new build house CU in the UK Electrical Forum area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
