A farmer wants me to run a new supply to a building, it's to be run in 35mm armoured, part of the route is a 25m overhead span between buildings, is this okay for the cable or should I be getting an extra pole in the middle put in to take the weight
Discuss Running 35mm armoured overhead in the UK Electrical Forum area at ElectriciansForums.net
Oops missed that bit!!...ha haunsupported over 25m?
if there are no supports over the 25m i recon it might dislodge a brick before landing on the groundOops missed that bit!!...ha ha
You need to completely redesign the whole job, it is not possible to support a cable that size on cateenery wire over that distance, a rethink, no point trying to continue down the cateenery route, just pointless.Yes it's 3 core armoured, the overhead part is not in a.through vehicle route and not possible to go underground as it's over a few smaller sheds
Good advice, I agree a ladder with supports or get it in the ground.A cable of that size run overhead should be fully supported and usually with heavy duty cable ladder, this would also require frequent support poles as you have to account for the weight of the ladder too and its max unsupported recommendations (at a guess every 5m) and been a farm then at a suitable height for farm plant to cross under even with any folks etc raised.
I would be seriously looking into burying this given the cost and obvious hazards having a overhead system with multiple supports would present on a farm.
might do it. 100m of 35mm 4c is 240kg so should work.RS do a 30mtr catenary kit that seems to carry 130kg ? and the dia. is only 3.0mm ??.Today i was looking at a catenary suspended between poles for street lighting approx 25mtr apart total run about 200mtr cable looked about a 25mm swa ? (i was driving at the time ) very little sag between poles and its been there for years.
thats the problem.Correct but if distance is only 25mtr pole might not be required but the fixing of the catenary at each end needs to be paramount
An experienced Time served Electrician wouldn't consider it :icon12:RS do a 30mtr catenary kit that seems to carry 130kg ? and the dia. is only 3.0mm ??.Today i was looking at a catenary suspended between poles for street lighting approx 25mtr apart total run about 200mtr cable looked about a 25mm swa ? (i was driving at the time ) very little sag between poles and its been there for years.
thats the thing it soon gets expensive, one of the biggest reasons the dno goes above surface is its cheaper than burying and making good in certain cases.Catenary is possible, but you'd need to sink two proper telegraph poles, plus counter anchoring. He's gonna need deep pockets!
If you're going overhead, I'd also ditch the SWA and go for HO7RNF.
Reply to Running 35mm armoured overhead in the UK Electrical Forum area at ElectriciansForums.net
