Running cables through a cavity | on ElectriciansForums
Discuss Running cables through a cavity in the Australia area at ElectriciansForums.net
DNS1
Just seen someone mention on another thread that running cables in a cavity is bad practice.
Can anyone elaborate for me, I was under the impression that this was ok but not ideal in a new build etc.
How should it be done these days? I'm in a 1990s flat and just wondering how a rewire will be possible without completely trashing ALL the plasterboard!
I believe it's the practice of running cables up/through an external cavity wall, i.e, from an external meter cabinet upward to an internal DB, that is frowned upon as you are bridging the moisture gap.
Also there is no support offered to the cables and they could be subject to damage that you wouldn't be aware of.
Agree. Most new builds have cavity walls anyway, When it comes to rewiring we wont be doing it in trunking. Fishing cables down the walls everytime for me, Aslong as its within the zones but i would never run cables down a cavity between the internal and external skin of the building.
sorry to change subject alittle but,as u say lenny bridging moisture gap, how does that relate to the pump in type cavity wall insulation. had mine done 2yrs ago now seem to have a lot of damp. any advice anyone?
Used to be done though, seen a few wired from new like that, all circuits run down the cavities and then through to points. Terrible really, all that cable just hanging on concrete block edges....great holes through to the cavity. Not the way to do it but would struggle to justify that with a reg. common sense over rules!
Chop out, or run within the internal cavities, also make use of loft space and under dwelling space. If its solid ceiling and solid floor you can do on surface using decorative coving trunking from above or channel out the floor.
Chase out the wall in the correct zones....
Metal boxes, grommets and oval conduit........
Cables in external cavities does not comply with building regs, is bad practice as previously stated due to lack of support and subject to damage.
Do people not get taught this in apprenticeships?????
Reply to Running cables through a cavity in the Australia area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
