View the thread, titled "Running cables through a cavity" which is posted in Australia on Electricians Forums.
Just seen someone mention on another thread that running cables in a cavity is bad practice.
Can anyone elaborate for me, I was under the impression that this was ok but not ideal in a new build etc.
How should it be done these days? I'm in a 1990s flat and just wondering how a rewire will be possible without completely trashing ALL the plasterboard!
If the cables are run within the plaster you'll need rcd protection, you will never cut in 50mm in standard breeze block because you'll be breaking a reg from part A of the building regs.... Structure I think it is, Also I'm a Jib Approved spark thank you very much!
Are you kidding me?!?! Tails to the consumer unit we are talking about here!
Yes your method is correct for tails.
I should really start reading all the posts first. Lol
I was just referring to standard installation.
And yes straight through is fine.
I think you will find that the majority of domestic installs don't comply from what I have seen
I agree, I bet 99% of contractors out there just run them up the cavity and just keep it hush hush and I have no shame in staying I done and still do it this way. But if anyone does have another method bar the galv conduit route, be sure to let me know!
I've seen a lot of that. I always try to make a rewireable system using oval conduit to roof/floor void, this means cables can be replaced wit no disturbance of decoration.
Better practice I think, and quicker than clipping loads of cables
I suppose you could fuse down in meter box and run earth metallic sheathed cable to distribution board lol
Reply to the thread, titled "Running cables through a cavity" which is posted in Australia on Electricians Forums.
