Running electric to island.
Hi all.
I'm currently building an island in my kitchen which will contain a gas hob. I've cut a trench about 60mm wide from the edge wall to where I want everything popping up.
Plumber will be fitting a 22mm gas pipe wrapped in Denso tape before it is filled in with screed and then tiled.
My question is can I run my twin and earth in conduit in the same trench as the gas? I was thinking maybe with a spacer in there so the screed will create a barrier between them? Obvs each respective trade will do the work but just getting ideas if I need to did another bloody channel.
Thoughts and ideas please.
Thanks. S.
