Running Main Bonding Externally | Page 2 | on ElectriciansForums
Discuss Running Main Bonding Externally in the Australia area at ElectriciansForums.net
W
walec
Hello All,
Been asked to change some bathroom lights and other jobs at an old house recently but preliminary inspection shows there is no main bonding in the property. Unfortunately the incoming gas is one side of the house and the water the other, both in the middle and the CU and meter at the front of the house (PME), there is no way of running one cable between the two and no way of running the cable internally (without making a hell of a mess) so the only option is to run externally. I want to mechanically protect the 10mm cable but 20mm conduit seems a bit of an overkill, so I am asking for any help/ideas on mechanical protection, its a 20M run either side of the house and I will even have to go up and around a porch as well! Customer has also said they want black as the guttering is black so I dont see many options. Thanks
Hasn't the resistance of a main bond got to be 0.05ohms or less? If that is the case OP could be struggling running it around the house because you only have 27 metres before you would have to increase the csa!
Reply to Running Main Bonding Externally in the Australia area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
Yeh im unsure without a photo of external box.
