Running of SWA, sub main | on ElectriciansForums
Discuss Running of SWA, sub main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
monmouthshire
Hi guys,
I am just trying to price a job up, which I am a bit unsure of. It is at a commercial premises, the supply I have got is 300a three phase, with ruffley 150a - 200a per phase already being used. The customer has asked me to run a supply, 300m (buried) for a 50kw load. It will supply staff living quarters, like a three storey house, and also possible expention in the future.
I have calculated the cable to 70mm2 SWA, 4core, with a 50mm2 earth. Do you think I should still put a earth rod in at the load side, house side?
Also a bit in unsure on protection, I calculated 125a 60947-2?
And then I was thinking of splitting the phases for each floor at the house, so ground floor L1, 1st floor L2 + 2nd floor L3?
Any help will me much appreciated
What ever size cable it doesn’t matter. By asking on here you show you’re out of your depth completely. How did you get to quote for this job?
Just a warning mate. If you are qualified, but presumably working for someone else atm, do you have public liability in place just in case something were to go wrong?
Kibble, I know nothing about 3-phase but I know if I were to use one phase for each floor of a dwelling then I would have 400v between Lines in the ceiling.
Laurie
Reply to Running of SWA, sub main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
