deano44
Hi all im new here so please be nice lol , im planning a job to run electrics to a shed so i can run 2 small chest freezers and a tumble dryer , my plan is to come out of my main consumer unit in the house with 6mm twin and earth cable from a 45 amp mcb , i will be running this cable through plastic conduit outside the house above ground about 30 metres in length , inside the shed i have a 5 way consumer unit running 2 6amp mcbs for 2 strip lights and 2 120 watt security lights , i have 2 32amp mcbs running 2 separate ring mains with 4 double sockets off each , i also have a 10mm earth cable of consumer unit in shed connected to an earth rod
in the ground , the question is , will this set up be man enough for what i need or have i missed something out ??
