Is it not possible to go upto 50 S/O's if each has its own FCU?
Technically yes although if you mean all off one socket originating on the ring it's bad practice.
What would have to be considered here would be the maximum floor space that can be served and the Zs value at the furthest point. Maximum floor space can be found in Appendix 15.
If you mean 50 S/O as 50 individual spurs at various points in the ring than yes this could be done.
Running Radial From Ring
Talk Electrician Forum
SKY,
SimpleSimon,
