Running Seperate CPC to light fitting HELP PLEASE | on ElectriciansForums
Discuss Running Seperate CPC to light fitting HELP PLEASE in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys
A customer wants to replace a class 2 fitting with a class 1 the lighting circuit does not have a CPC, I want to run a seperate 1.5mm CPC but as its less than 4mm does it need mechanical protection? And is it acceptable to only run it to the fitting in question?
Your help with this would be appreciated
Many Thanks
T&E
Not as good on the reg's as some of the guys on here but i would say yes you do need mechanical protection for 1.5mm so why not just run a 4.0mm?
As for 2nd part of question i would say yes.
If i am wrong we will know very soon!
Hi Guys
Many Thanks
T&E
you can clip the single earth or trunking upto the ceiling soon as you are under the upstairs floor your ok
in a real life situation, i'd be inclined to run 1.5mm. remember that BS7671 is not statutory and if you consider that 1.5mm will provide adequate fault protection, then go ahead. tin hat on.
Reply to Running Seperate CPC to light fitting HELP PLEASE in the UK Electrical Forum area at ElectriciansForums.net
Yes agreed this is definitely out of my comfort zone and it was from the start. Connecting the lights on to scaffold just had me on edge. So the...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
