N
newuser31555
Hello All,
I am in the middle of sorting my audio visual out including adding extra power sockets (7 in total = 3x2gang 1x1gang) which is fed a via plug and lead and adding a network cable to a non internet connected router. The network cable is a category 5e UTP patch cable 4 pairs 24 awg the router is a old dlink broadband router which has wifi. I have central server. the cable will be running throught a airing cupboard which houses a FM signal amplifer which is powered from 4 gang socket extension lead (13 amp fuse in the plug). My question is that could I run the category 5e UTP patch cable 4 pairs 24 awg next to the power supply (13 amp)? without any interference? The actual info was found on the network cable.
