Y
yepyep
Hi all,I have to go look at a job, from what i understand, they have an S plan in, they have had an sunroom extension with UFH so this is to be controlled independantly of the HW/CH.
the plumber has a motorised valve at the boiler for the UFH zone which is pumped to the sunroom, there he has another pump to pump round the UFH zone, this pump apparently has a sensor so will only pump when it detects teperature in the pipes. there is also a room stat in the new sun room, so i think basically the room stat provides a switched live to the pump, which in turn will only run when it detects temp in the UFH zone, which in turn is supplied form the new motorised valve.
my question is does anyone know of any decent 3 zone time clocks, ideally not mechanical.
cheers
cheers
