Safe Isolation Procedures HELP! | on ElectriciansForums
Discuss Safe Isolation Procedures HELP! in the UK Electrical Forum area at ElectriciansForums.net
J
JuniorSparks
I'm a little stuck on the different types of safe isolation procedures
the questions I've been asked are as follows
demonstration of the full, safe isolation procedure required in order to carry out electrical work/maintenance to items of electrical equipment
a) single phase circuit
b) single phase distribution board
c) three phase circuit
d) three phase isolator
any help would be much appreciated, also if anyone has any links to the HSE safe isolation information or anything like that I can't seem to find anything
Method statements for safe isolation of a three-phase circuit
Does anybody have a full method statement detailing the full safe isolation procedure for a three-phase circuit?
Ive never done a method statement but have been asked to do one for this specific task,
Re: Method statements for safe isolation of a three-phase circuit
First thing you need to do is a risk assessment. Then once you have this done identifying all the risks, create the methodology to reduce the risks to a safe level. Have a think about it and it should come to you.
sorry my bad I've probably worded it wrong, I basically need a step by step guide to safe isolation of a three phase circuit
FFS, are you AT college?
In my experience, the content is TAUGHT, then questions set to check your understanding.
If you don't understand...ask the lecturer.
That's what they're there for.
so, my Dear Watson, I conclude the OP is a 'distance learner'....or a wind up,,,,in which case - go forth and procreate.
yes I am at college... And no I haven't been taught safe isolation procedures yet only I have been set a task to research different types of safe isolation procedures
- - - Updated - - -
search the forum on inspection and testing as there are loads of threads covering this
Cheers!
Reply to Safe Isolation Procedures HELP! in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
How did it go?
