Safely split ceiling lamp for three bulbs. | Page 3 | on ElectriciansForums
Discuss Safely split ceiling lamp for three bulbs. in the Lighting Forum area at ElectriciansForums.net
You're working under Austrian rules, but in the UK that assumption needs to be checked with the appropriate test equipment.
I'll have to ask my Austrian buddy. Thankfully I have my mulitmeter 8,000 miles away in my LA storage unit.
But regardless of UK or Austria, is it common to plug G to G the same way you plug L to L and N to N when using push connectors for lamp fixtures in ceilings?
Yes, the grounds can be joined together in the same way as the lives and neutrals. The only difference is that the connector for the grounds isn't required to be inside an enclosure, like that for the lives and neutrals, but would normally be enclosed with the others.
Interesting. I guess my next concern is the enclosure you're speaking of.
I don't have an enclosure for the Wago connectors.
I have an enclosure from the ceiling naturally for the extension cord I'll be connecting.
But once I get to the drift wood/lamp I've made, I was just going to neatly tuck the cabling out of sight (it hangs way overhead out of sight) Is it safe to just wrap the WAGO connector in electric tape?
Alright - tried to make it as clean as possible and it works great.
No housing for the WAGO connectors, but I wrapped em in a bit of electrical tape. What do you guys think?[ElectriciansForums.net] Safely split ceiling lamp for three bulbs.
  • [ElectriciansForums.net] Safely split ceiling lamp for three bulbs.
We don’t know Austrian regs… so the need for an enclosure may not be the same as it is in UK. but the fact you can get WAGOs suggests you can get the boxes too.
Can you expand on the closure and why? What does the enclosure protect?
One of the principles of electrical safety is that no single failure should cause a hazard.
So cables have two layers of insulation, on the individual wires, and then a sheath over.
And when you come to join cables, you put all the single insulated wires in a box to provide the second layer of insulation, and this also means that if a live wire were to come out of a Wago connector, it would be contained within the box, and not be a hazard to someone touching it.
So in the UK it is mandatory to put wire joints in a suitable insulated box, including all single insulated wires, and anchor the cables.
You should not be able to see the single insulated coloured wires, or the connectors.
I imagine the regulations are the same where you are!
OOPS, didn’t spot that the post related to Australia
the advice I have given is still sound, it would be safer if contained in a box.
however I can’t comment on the wiring regulations down under so it may or may not be a legal requirement.
This article is pretty good.
Great read. Thank you.
So, everyone seems to be explaining the same thing which I now understand - regardless of a countries code, it appears to be a good practice.
In my apartment, I have plenty of exposed (unsheathed) cables hanging from the ceiling where we have not placed a nice lamp yet. So, if this were code in Austria, then it’s already a flag. Perhaps a C3 as the article explained as nobody is reaching up there to touch it without a ladder.
In my case, all of the unsheathed cables in their wago connectors are tucked away behind wood as seen in the photos. I’ve applied electric tape to not only identify which is which more easily, but to also further protect any cabling to accidentally become undone- which I believe the chances of that happening are slim to known as there’s no traffic up there. If anyone is touching anything it’s me in efforts of making it cleaner than it is.
Secondly, it’s surrounded by wood, so nothing is conducting electricity there should the unlikely event that anything come undone.
In conclusion, I believe it’s okay as it is, but I can be a bit obsessive over doing things correctly. So my take away from all your help is that despite the LNG connectors being close together, having them enclosed in a plastic housing unit so that no unsheathed cabling is visible, would make the wiring the most safe?
Although branded 'Wagobox', the enclosures we commonly use are from a British company, Connexbox (manufactured, I believe, with agreement of Wago). Not sure what enclosures, if any, are made by Wago themselves.
Reply to Safely split ceiling lamp for three bulbs. in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
