Rossi
Hi all, I drilled a hole to fit a new cooker hood and had no shock etc when drilling. When I was cleaning the hole out to put the rawl plug in I got a small tingle (no smoke, spark, bang etc). Is it possible I've nicked a wire or just come close to one? I used a metal/ voltage finder and nothing showed. It's an old house and the walls are thick so wires rarely pick up on the detector anyway. I've ended up putting a shorter rawl plug and screw in. Any advice? Is it worth getting an electrician in to look at it? Looking at the lay out of the sockets and previous holes I'm not sure how a wire could be there?? It's the hole circled on the photo I've attached. Any advice appreciated
