safety cluth drill for core cutting | on ElectriciansForums
Discuss safety cluth drill for core cutting in the UK Electrical Forum area at ElectriciansForums.net
T
thelondonway
best ones ?
decent priced core cutters also anyone know of any for 4" holes prob 115mm core
I have still got my ELU Diamante 110 v 1300 watts with rcd on the cable, i have cored 100's of holes with this mainly 117 & 127 it is still going strong even lending it out several times, had a new cable that's all. Dewalt took over ELU but i think they still make it albeit yellow in colour. It was a good investment along with the MIT88 wall chaser & extractor to go with it. Boy does that take away the chor of chasing out. A good dedicated core drill would cost between 3-4 hundred quid from new if you are going to use it on a regular basis.
want your arse wiped too?
Def would need a risk ASSesment.
49.99 is the big sds for drilling and chisel attachments.
I used it last summer for breaking concrete and coring it to break it, wet cores, 2 inch to 4 inch. They have a clutch too.
Lets face it, 50 quid is throw away money, what would it cost to hire one?
Boydy
Reply to safety cluth drill for core cutting in the UK Electrical Forum area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
