Sanity check, RCD or what..... | Page 2 | on ElectriciansForums
Discuss Sanity check, RCD or what..... in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
A friend of mine has just called me up for a bit of advice and I said I would double check with you guys and girls who are perhaps older and wiser or just wise lol!
He has a coffee shop that has 2 distribution boards of approximately 10 ways each (both split dual RCD boards). One of his staff members called him up saying the power to numerous circuits had gone, but stayed on for others. The first time it went for about 30 seconds then came back on, the second time it went off for about 5 mins then came back on again. He said they were all on one half of one of the boards. My thought process is it can only be a faulty RCCB unit (protecting half the board) but I have never known this before. Does this actually happen or am I completely wrong? It sounds like a mcb fault more than an RCCB fault but I cant explain it with half the board going??
Many thanks in advance,
Martin
Eicr with the boss and when he was checking tightness of screws there was fizzling - 1 bus bar on wrong side of tightening mechanism. Unfortunately it had seized the mcb so we had to replace. Been like that 12 years!
How long have short courses been around?
[ElectriciansForums.net] Sanity check, RCD or what.....
Reply to Sanity check, RCD or what..... in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
It might be worth asking the customer to turn the oven on 45min before you arrive. then do an IR test on the oven from the isolator with the oven...
