SAP 2009 Table H2 - Which Row? | on ElectriciansForums
Discuss SAP 2009 Table H2 - Which Row? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
T
T0M0
Hi All,
I have been using the horizontal row of table H2 for roofs <30 degrees. Discovered recently that I should be using the 30 degrees row for angles approaching it. I cannot find any conclusive advice as to what to use.
Which row should be used for <30 degrees?
Any help appreciated and thanks for reading.
T0M0
Most of ours are on Ag barns so are around 12-15 degree we always give Horizontal and 30 degree , then explain in reality its somewhere in the middle !
Can not see what else to do really ?
Yes sorry , just reread thread title and Ramjam is correct we run to 2005 not 2009 .
I find the SAP calc so blunt and inaccurate that I put the all the selections upon which the estimate is based on the benefit calc for them to see. Then I explain how bad it is but that I'm obliged to give them that estimate and that in our location they will outperform it by about 15% which is the figure that after much testing SAP against PVGIS I seem to always come to.
Reply to SAP 2009 Table H2 - Which Row? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I think you mentioned changes bulbs in one message then change lights. There is a difference. Are you changing a bulb or a light fixture? If...
2 3 4 5 6 7
5K
Cbelectrics
C
This is an RSS feed of thread: Pura shower head - too much weight for a tiny thread Content of the thread: Hi there, Hopefully someone will be...
