Sauna Heater Help! - What Cable | Page 3 | on ElectriciansForums
Discuss Sauna Heater Help! - What Cable in the UK Electrical Forum area at ElectriciansForums.net
Weezy
England
As short as possible.
My customer has brought a sauna heater that’s made in the USA the manual is VERY poor, it states that the cable to the heater should be ‘REVE or equivalent’
I took the manual to Edmundsons Electircal wholesalers and they had no clue what that was...
Ed’s said they would look into it, not heard back from them.
I emailed the manufacture in USA, not heard back from them.
Iv done some research and i believe sauna heaters normally range from 75 degree’s to 98 degree’s.
Ordinary pvc t&e cannot be used Swa cannot be used.
Iv read that you can buy H07rn-f cable but this is only rated to 85degrees. So surely this won’t do?
I also read some electricians use HTF cable? i also asked Ed’s for any of this which he also had no idea on...
I did think of using Butyl cable but i’m not 100% sure what it’s current rating is? ideally i need 6mm but it seems almost impossible to buy, they do sell 4mm but is 4mm butyl rated at 32amps like normal T&E pvc/pvc 4mm?
So i’m totally at a lost end, part of me is thinking will the temps ever reach 98 degrees, what do i do?
p.s I really don’t want to use pyro...
The manual for my heater states "wire from controller to heater needs to be UL62 approved to 105C". I found SJEEOW wire on McMaster Carr. Can buy a 10-foot piece for $22.
My question is: Does NEC allow SJEEOW to be placed in studs in wall (similar to Romex)?
The answer is no, you need to buy 6/3 with ground that’s approved for outdoor use. The insulation for SJEEOW and it’s not good for 60 amps.
All your wire needs to be # 6. Your manual actually states 60 amps. Do not use short cuts on cheap wire. Especially any kind of SO cable
No short cuts here. My manual states 10 Ga wire rated to 105C. The wire I bought is 10 Ga and rated to 105C.
My question is: Can I run SJEEOW in the wall? An electrician I called (before I got the SJEEOW), said "Only Romex in wall, has to be insulated".
  • [ElectriciansForums.net] Sauna Heater Help! - What Cable
Article 400.12 states it is not permitted to run through holes in walls. It will handle 30 amps and it’s not approved for wet locations
No he won’t flip out but why metal and not PVC conduit
That's a good question... I bought flexible metal already! Can probably return that and go with cheaper PVC.... in fact I probably have a 3 foot chunk in the office that I can use. Looking for a deep feedthrough to go through the 5/8" cedar, will probably have to put a metal plate there?
Yes every stud you drill through you have to install a nail plate which you can purchase at Home Depot and Lowe’s or your local electrical parts house. Good luck
Reply to Sauna Heater Help! - What Cable in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
