Sav-wire | on ElectriciansForums
Discuss Sav-wire in the UK Electrical Forum area at ElectriciansForums.net
C
cristafar
Hi there, was just wondering if someone could give me some insite to how sav-wire bases work? And with sav wire do all components have to be sav wire compatible, eg sounders call points etc? Im thinking with sav wire u can have sounders on same circuit as the detection etc. so if a sounder was the furthest point on a circuit this would be e.o.l? Any knowledge would be appreciated.
Reply to Sav-wire in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
