If the inverters are the SB2500HF, then yes, as you can connect by bluetooth you can change the individual parameters to G59 settings, but I do not believe they have G59 certification so you would probably need a separate G59 relay to satisfy the DNO.
If they are the older design, SB2500, then you cannot connect by bluetooth 'out of the box' so cannot easily adjust the parameters. However, looking at the installation manual it does imply that you can change the country settings etc with appropriate software and hardware so might be possible. Again they have no G59 certification so I think you will be forced to get a G59 relay.
