I tried to post this yesterday, but it didn't work, presumably as it had an embedded results table from PVSOL:-
"Interesting enough, if you compare simulations in PVSOl for a SE (6 ET Solar panels), SW (8 panels) into a 3600TL (based on 4000TL as PVSOl doesn't have the 3600), a 3000TL-21 (new 2 tracker version of the 3000TL) and say a Power-One 3.0 (2 tracker) then the Power-one comes out about 2.5% ahead, but the 3600TL is the same as the 3000TL-20."
The feed-in figures from PVSOL (assuming London SE/SW at 31 degress incline) are respectively (3600, 3000TL-21 and Power-One): 2305, 2304, 2369kWh
As Gavin has previously stated, SMA design 'green ticks' the 3600TL on everything (startup voltage, mppt range etc), the only thing it questions is the oversize of the inverter. And the 3000TL-21 (twin MPPT which wasn't previously available) although it is within SMAs normal +/- 20% capacity range doesn't have any greater efficiency/yield.
