View the thread, titled "SBS Trade consumer units" which is posted in Electrical Tools and Products on Electricians Forums.
A small sub main to the top floor to a small CU for sockets and lighting ?
Distribution circuit to an old under-floor heating board?
It's a relief that you guys are almost quoting the conversation I had with the owner!
I'd eventually written the 6mm off as (probably) an old shower circuit. I left it disconnected at that point.
I later did a walk around with him to find out what didn't work as I'd also got two 2.5 cables disconnected that had been both in a B32 but I had no end-to end readings.
We found three double sockets in lounge not working.
Then a bit later we found a macerator en-suite toilet (which was directly above lounge) not working.
I temporarily connected each half of the non-ring to a B16 and found one cable got one corner of the lounge working, the other cable got the other corner working. Neither cable got the macerator working...
It still didn't dawn on me until I took the FCU apart and it was the 6mm feed, almost certainly the old shower circuit from the next room repurposed. The guy (who was Dutch) found this really funny and said does that mean I can do a 32 amp sh*t then?
A 40 dependent on how bad the runs are :)
SBS Trade Sales ceased trading last month. Apparently they will offer support to existing customers from available stock.
No idea what happened, but I do remember expressing concerns on other threads about their business model leading to such an occurrence.
It's a shame that, but as you say it was always a worry that this might happen at some point.
David Savery was a big advocate for them, liking the fact that the diyer couldn't purchase..
That was a good selling point, but the problem was they also limited access for trade customers who had to go directly to them and register an account.
While I admired their stance on sales to DIYers, it seemed foolhardy to also make it difficult for trade customers to give their business to you. Most sparks will buy whatever is stocked locally. A smaller number will prepare in advance to ensure they can use a preferred brand. Very few are going to exclusively use a brand that's available from only one source and for which no alternative exists should any item be out of stock.
David Savery put out a video on YouTube about SBS going out of business. In it, he does make some interesting points about (most) other manufacturers effectively discontinuing products by not making them backwards compatible.
Must take a look at that. I have strong opinions about backward compatibility and it's one of the reasons I like Starbreaker, unlike a well known Electrium stablemate. Hager also deserve credit for moving in the same direction. I've placed a bit of faith in Fusebox and (to date) they seem to have a similar ethos where backward compatibility is concerned.
Unfortunately I think the majority of money is spent along the lines of price and local availability, so there's no real incentive for manufacturers to move in this direction.
I don know how/if they verify non-scam victims.
I described my very part time business and sent some photos of previous work - he said OK.
That is indeed disappointing news. I'm now wondering if I should grab some additional RCBOs to cover potential additions at church.
But, they didn't make the stuff. The box fronts are branded (from memory) LVE or something like that. So I do wonder about the scope for alternative supplies ?
I've read before the claim that SBS circuit protection was made by Live, but don't know whether there's any truth in the rumour. Do live offer a dual busbar option?
Well, when I did the church electrics, the bixes were Live branded, as was the 4pole switch (for c/o to gen input) he fitted for me in place of the 2pole main switch. The style of the Live branded switch was identical to the normal main switch.
But I've looked on their site Live - https://www.liveelectrical.co.uk/ and can't see them.
So it's quite possible he's been using Live boxes but "someone elses" internals.
Certainly going to be an issue if we can't find an alternative. At least the boxes are spacious so could fit the much longer AFDD+RCBO devices Arc Fault Detection Device With RCBO - https://www.liveelectrical.co.uk/Catalogue/Arc-Fault-Detection-Device-With-RCBO_ID163.html. pity it'll mean having to take out the dual busbar and scrap existing devices to reolace it with a single bus bar.
Reply to the thread, titled "SBS Trade consumer units" which is posted in Electrical Tools and Products on Electricians Forums.
timhoward
Broke Internet
Supporter
Oswestry
timhoward,
ufarooq,
