SCC rating ... | on ElectriciansForums
Discuss SCC rating ... in the UK Electrical Forum area at ElectriciansForums.net
Hampshire
Hi All
In the process of entering data for a recent EICR and could do with a little help to fill in a blank field ...
Short Circuit Current Rating for ... a Wylex 100A 100mA DP RCD BS4293 not time delayed.
I did look when on site, but couldn't spot it on the device, front or sides and don't fancy a long drive back to site to power the site down so I can disconnect it to check the back of it, besides something tells me it would be a wasted journey anyway.​
If anyone can help out with an answer, or can post a link to another forum where this has already been answered that would be very handy thank you ... sorry, but I can't find one, maybe I'm having a bad day using the search facility, but keeping my fingers crossed someone will be able to help.
Paul
It's not a main switch within a DB, but an isolator in it's own enclosure in the meter tails.
Maybe I'm being a little ----, but there is a circuit from the meter to the RCD in question, then a circuit from the RCD in question to a set of service blocks that in turn feed a DB and isolator supplying a remote building.
wrong terminology in my previous post . The rcd only detects earth leakage . It is not rated to disconnect faults of a ka rating .
What certs are you using ?
I maybe wrong but I disagree, I suspect it does have a maximum fault current rating.
Have emailed electrium who make Wylex but not sure when I'll get a reply as it was well.past office hours hence my asking here in case the wealth of knowledge could give me an answer sooner.
Thanks for feedback to date, will let you know what, if any, reply is forthcoming from Electrium/Wylex.
PIRform is the software in question.
Reply to SCC rating ... in the UK Electrical Forum area at ElectriciansForums.net
