Schneider C60HB 3 pole 63A MCB | Page 2 | on ElectriciansForums
Discuss Schneider C60HB 3 pole 63A MCB in the UK Electrical Forum area at ElectriciansForums.net
B
BathSparks
Can I connect the meter tails into the top of this MCB and the load cable (SWA) out of the bottom. The MCB is not marked for in and out and I cannot find any info on Schneider's web site indicating this is not possible.
  • [ElectriciansForums.net] Schneider C60HB 3 pole 63A MCB
Hi,
Probably not the way things are done now, but I was always taught and still do it now, supply in the bottom terminals and load out the top. Either way though and the isolator/switch will still operate correctly.
Regards.
Reply to Schneider C60HB 3 pole 63A MCB in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
