Schneider Domestic boards... | on ElectriciansForums
Discuss Schneider Domestic boards... in the Domestic Electrician Forum area at ElectriciansForums.net
DNS1
Anyone got any opinions on the above?
Not used them before, but they seem pretty cheap in comparison to equivalent MK/Crabtree etc.
Iv just had 3 fitted in my house (conversion from a pub), I supplied them my electrician was very impressed wasn't a brand he normally used.
Only the bottom one is currently live supplying power to the flat above where I'm living.
Here is the pics
I use them quite a lot and I find them to be very good boards. They are a bit tight in terms of space to terminate into the MCB's but if you plan where you put your cables first then you won't have too many issues.
Reply to Schneider Domestic boards... in the Domestic Electrician Forum area at ElectriciansForums.net
Glad you got it sorted.
P
16 Square Meter Domestic Bathroom Tiling Work Malton North Yorkshire I have a job in Malton North Yorkshire, and I’m giving it a try on here (you...
PETERHA
P
