joel89
Hi has anyone ever used these before and the software? We usually use allen bradley micrologix or control logix, but for a small job I am doing I have been told to use these, it is for a forge I am building a 400amp inverter panel for a large motor turning a big crank, all the zelio is needed for is to turn water and air supplies on and off at set time periods, it is designed to cool and finish the forged cylinder neck, as they easy to work with or complicated?
cheers Joel
cheers Joel
