djboyd
Hi folks
Hope someone can lend a bit of advice. Was round at a friends today as she was concerned about her washing machine - so she should be. It was connected to a very cheap looking 3 way extension along with a fridge and a tumble dryer. Clearly this was overloaded. However, the scorching had occurred only on the neutral conductor of the socket (on the extension) supplying the washing machine, not as you might expect the wall socket supplying the extension lead. Have binned the extension lead and suggested that she uses the twin socket to supply each high power device but before re-connecting the washing machine want to make sure that all is ok and it is not likely a fault with the machine.
Thanks.
ps - I am a regular on the plumbing forum, first time on the electricians version!
Thanks.
