Darkwood
True, but not uncommon on long conveyors on power stations, quarries etc. We have installed conveyors with 250kW and 355kW LV motors, currents up to 750A, on VSD's. Some long cable runs too, SWA's in parallel, and I've never seen any connected in SY. It would just not be accepted by the customer engineer, nowhere near robust enough in that environment.
We always run the protective conductor separately, so 3 core SWA's.
There are plenty of specialised cables for quarries, mines etc that you won't find in your local wholesalers, if you do this kind of work you will be familiar with the cabling used and how to source them, SWA as we buy at our wholesalers is just one type of many variants of SWA so to simply say SWA as a particular type of cable used is no longer enough info for the direction this thread is heading and more specific info is needed.
