Just been browsing eBay for a snap-on ratchet...
is there any differences between the various colours and styles?
i see a red , orange , green , yellow & black in a hard plastic
and various what look like a soft grip version
is That the only main difference...??
basically, yes. the only problem with the soft-grip version is that the cap falls off when using it and spare bits in the handle fall out, usually never to be seen again.
upside is guaranteed for life. i had the ratchet fail on one. snap-on rep fixed in his van in 15 minutes. FOC.
If I can pick one up for £25-30 on eBay I will get meself one and give it a bash...
i see they do limited edition pink version , so might buy it for the wife for Christmas...;)
[automerge]1595156250[/automerge]
On a side note my Klein & milwakee insulated screwdrivers I ordered should arrive tomorrow so I will try them for a week and give my opinion on them.
never tried Klein or milwakee Insulated screwdrivers Before,
I did have a Klein normal screwdriver once upon a time before I lost it...
well my parcel arrived today, 3 Klein slotted and 2 milwakee pozi drivers.
the kleins have a decent grip so reckon they will be good to use but the milwakee feel rock hard , smooth and quite slippy...
see how they go , but reckon the miwakee will end up on ebay
Yeah the Milwaukee ones are rebranded cheap rubbish. They honestly feel like the Aldi ones.
more than likely , they feel like generic cheap screwdrivers you get in a pack from Aldi For a fiver.
the grip is horrible and plasticy.
only paid like 3 quid each as they were on offer
im just going to bid on a snap on and just noticed not all are the same size Shaft.
standard screwdriver bits are a 1/4 inch bit...?
are all snap on are 1/4 inch ??? I don’t want to end up with some funky American size I can’t get bits for
snap-on drivers are 1/4" square shaft into handle and standard hexagonal bits like any other interchangeable bit driver. however i think you can get shafts with 1/4" sq. end for use with sockets. the pic in my post 57 appears to be this. the shafts are interchangeable so buy one with the hex end for bits as you can get hex to sq, adaptors, if that makes sense.
Well the milwakee screwdrivers ended up in the bin , the small 3mm slotted tip snapped after about 2 uses...
absolute garbage , how Milwaukee can put there name to these screwdrivers beggers belief...
thank Tel...
if you were going to buy w snap on ratchet screwdriver would you opt for the soft grip or hard plastic handle...?
