Screws on Metal Backbox won’t tighten. | Page 2 | on ElectriciansForums
Discuss Screws on Metal Backbox won’t tighten. in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
Liverpool
I’ve been changing some sockets and the last one won’t tighten. They have used 75mm screws. The screw just slides into the lug. I’ve got a CK 3.5mm tap and tried that. Still no luck. Has anyone any tips or tricks? Or any screws that I could buy to make it tighter in the lug?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
If it’s the adjustable, you might be able to fold out the retaining tabs, slide out the lug and replace it with one from another box of the same make.... or if it’s a 4 lug box, use one of the unused lugs.
Screw in a fixing screw to hold the lug in place while you fold in the tabs again.
it’s all a bit fiddly, but better than using wood screws.
Drill and tap M3 hole in rear of back box, then use a screw that is not too long that it hits the brick/block or whatever is behind the box. Screws can be trimmed nicely to length with the M3.5 cutting holes in my VDE pliers.
I had something similar with these, on a 2gang (not a double) backbox, a few months back.
[ElectriciansForums.net] Screws on Metal Backbox won’t tighten.
I started to replace the faulty timer but the new one was slightly bigger and wouldn't sit above the FCU.
It was a bit testing with the drilling angles, especially when the the tap snapped on the second hole....?
I always use some basic crimpers with threaded screw cutters, by the way. Save a lot of problems.
if it's a sliding lug, swipe one from another box. if fixed, i drill
It’s the adjustable lug. How do you swap them out?
sliding lug - just bend up 1 of the retaining tabs a tad, slip new lug in and secure.
for fixed lug I cut off the lug, then drill the box directly behind 6mm, then 5,5mm masonry bit into wall followed with a red wall plug into which I screw an extender.then I have a fresh new 3.5mm hole
Thanks Tel. I will grab a backbox from Screwfix in the way home
Thanks Tel, I will grab a backbox from Screwfix, I will see if they do the extenders too.
@ screwfux, extenders just under £3 for 10.
Reply to Screws on Metal Backbox won’t tighten. in the UK Electrical Forum area at ElectriciansForums.net
